This was a hard decision...for me anyhow
Well,
What can I say. You made your decision.
I would make a different decision.
For 30 bucks unless it is a piece of rust inside, no speakers and everything is screwed up, this is not even a steal, it is a highway robbery.
I would not ask questions, I would grab it and run as fast as I could with this radio in hands before he changed his mind.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
