Philco 66 Lowboy
It is a decent radio. Nothing really stellar but decent. For 25 bucks - good buy.
Philco 66 Lowboy - by Crist Rigotti - 07-12-2015, 03:20 PM
RE: Philco 66 Lowboy - by morzh - 07-12-2015, 03:37 PM
RE: Philco 66 Lowboy - by Ron Ramirez - 07-12-2015, 04:53 PM
RE: Philco 66 Lowboy - by Nathan Slingerland - 07-12-2015, 05:03 PM
RE: Philco 66 Lowboy - by Radioroslyn - 07-12-2015, 06:30 PM
RE: Philco 66 Lowboy - by morzh - 07-12-2015, 07:24 PM
RE: Philco 66 Lowboy - by Crist Rigotti - 07-12-2015, 07:27 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
