half the tubes check bad
There are more to the radio than just tubes. RF coils that can get open, oxidized panels and switches, speaker, transformer.....so, start telling us what you have checked so far.
half the tubes check bad - by doc612 - 07-13-2015, 12:01 PM
RE: half the tubes check bad - by Nick3092 - 07-13-2015, 01:04 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:21 PM
RE: half the tubes check bad - by morzh - 07-13-2015, 01:14 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:22 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 01:40 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 01:41 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:25 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 08:36 PM
RE: half the tubes check bad - by doc612 - 09-09-2015, 11:19 PM
RE: half the tubes check bad - by klondike98 - 09-09-2015, 11:37 PM
RE: half the tubes check bad - by tom.seeger - 09-12-2015, 10:03 AM
There are currently 5906 online users. [Complete List]
» 2 Member(s) | 5904 Guest(s)
