half the tubes check bad
(07-13-2015, 01:14 PM)morzh Wrote:  There are more to the radio than just tubes. RF coils that can get open, oxidized panels and switches, speaker, transformer.....so, start telling us what you have checked so far.
I haven't checked anything else but tomorrow I am going to buy a magnifying lens so I can read the voltages on the schematic and we'll go from there.
half the tubes check bad - by doc612 - 07-13-2015, 12:01 PM
RE: half the tubes check bad - by Nick3092 - 07-13-2015, 01:04 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:21 PM
RE: half the tubes check bad - by morzh - 07-13-2015, 01:14 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:22 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 01:40 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 01:41 PM
RE: half the tubes check bad - by doc612 - 07-13-2015, 04:25 PM
RE: half the tubes check bad - by TA Forbes - 07-13-2015, 08:36 PM
RE: half the tubes check bad - by doc612 - 09-09-2015, 11:19 PM
RE: half the tubes check bad - by klondike98 - 09-09-2015, 11:37 PM
RE: half the tubes check bad - by tom.seeger - 09-12-2015, 10:03 AM
There are currently 7109 online users. [Complete List]
» 1 Member(s) | 7108 Guest(s)
