Philco Model 60 Restore
I just finished restoring a Philco Model 60 cathedral, and it works great an the AM Band. I have not done an alignment, though I did adjust the compensating condenser in the 6A7 oscillator circuit. It was motorboading badly when I brought it to life. After adjusting the condenser, it works great!
However, when I switch to the SW band I hear AM stations though they are weaker. I really don't care about the SW band, but I am haunted knowing that the radio is imperfect.
Where would I start to troubleshoot the SW band?
Thanks!
Mark K8KZ
Philco Model 60 Restore - by markmokris - 07-14-2015, 12:21 PM
RE: Philco Model 60 Restore - by morzh - 07-14-2015, 01:09 PM
There are currently 4092 online users. [Complete List]
» 1 Member(s) | 4091 Guest(s)
