Philco 46-1209 Code 121
I will check voltages and resistance this weekend and hopefully find an answer, but I have also questioned my choice of capacitor for the output plate bypass. It calls for a .003 @ 1000 v and I used a .005 @ 1000 v. as it was the closest I could find @ JustRadios. Would this cause an issue volume-wise?
Also, the paper capacitor I have not replaced yet is the .01 mfd Conv. Plate Decoupler. If this was not functioning properly, what would it's symptoms be?
Philco 46-1209 Code 121 - by heats00 - 07-07-2015, 11:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-08-2015, 12:15 AM
RE: Philco 46-1209 Code 121 - by klondike98 - 07-08-2015, 12:20 AM
RE: Philco 46-1209 Code 121 - by codefox1 - 07-08-2015, 08:56 AM
RE: Philco 46-1209 Code 121 - by Radioroslyn - 07-09-2015, 06:03 PM
RE: Philco 46-1209 Code 121 - by heats00 - 07-16-2015, 10:27 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-06-2015, 02:19 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-07-2015, 12:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-08-2015, 02:30 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-09-2015, 01:46 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-12-2015, 09:04 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-17-2015, 03:55 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-17-2015, 07:33 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-17-2015, 09:14 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-18-2015, 09:27 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-18-2015, 12:18 PM
RE: Philco 46-1209 Code 121 - by klondike98 - 08-18-2015, 01:02 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 01:00 AM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 11:13 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-19-2015, 03:23 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-19-2015, 07:22 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-20-2015, 10:56 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-21-2015, 11:33 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-21-2015, 03:49 PM
RE: Philco 46-1209 Code 121 - by heats00 - 08-30-2015, 11:21 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 11:05 AM
RE: Philco 46-1209 Code 121 - by heats00 - 08-31-2015, 12:28 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 08-31-2015, 04:45 PM
RE: Philco 46-1209 Code 121 - by heats00 - 09-03-2015, 11:55 PM
RE: Philco 46-1209 Code 121 - by OZ4 - 09-04-2015, 11:06 AM
There are currently 6962 online users. [Complete List]
» 2 Member(s) | 6960 Guest(s)
