Philco 42-400 121
Micro, I merged you new post with your original thread to keep things together. The push button info is in the service info. You can get all the service info for your set from Chuck Schwark but I doubt he has the owners manual...ask him. You may need to align the set.
Philco 42-400 121 - by Microtouch - 01-25-2015, 01:39 PM
RE: Philco 42-400 121 - by klondike98 - 01-25-2015, 03:33 PM
RE: Philco 42-400 121 - by Ron Ramirez - 01-25-2015, 03:38 PM
RE: Philco 42-400 121 - by Microtouch - 01-26-2015, 07:03 AM
RE: Philco 42-400 121 - by klondike98 - 07-17-2015, 02:44 PM
RE: Philco 42-400 121 - by Microtouch - 07-17-2015, 04:27 PM
RE: Philco 42-400 121 - by klondike98 - 07-17-2015, 07:34 PM
RE: Philco 42-400 121 - by Microtouch - 07-17-2015, 09:11 PM
RE: Philco 42-400 121 - by klondike98 - 07-18-2015, 11:13 AM
RE: Philco 42-400 121 - by mikethedruid - 07-21-2015, 07:32 PM
Update 42-400 - by Microtouch - 07-17-2015, 02:07 PM
There are currently 4050 online users. [Complete List]
» 1 Member(s) | 4049 Guest(s)
