Philco 42-400 121
Thanks for the response and the merge. I'll look again at the service sheets. I saw a brief on the push buttons but nothing specific. I assume some are presets but am unsure which ones select AM, SW, or FM. I was thinking too that the set may need to be aligned. I've not yet aligned a radio and am wondering whether or not it's a good idea to cut my teeth on this one.
Quando omni flunkus moritati.
Philco 42-400 121 - by Microtouch - 01-25-2015, 01:39 PM
RE: Philco 42-400 121 - by klondike98 - 01-25-2015, 03:33 PM
RE: Philco 42-400 121 - by Ron Ramirez - 01-25-2015, 03:38 PM
RE: Philco 42-400 121 - by Microtouch - 01-26-2015, 07:03 AM
RE: Philco 42-400 121 - by klondike98 - 07-17-2015, 02:44 PM
RE: Philco 42-400 121 - by Microtouch - 07-17-2015, 04:27 PM
RE: Philco 42-400 121 - by klondike98 - 07-17-2015, 07:34 PM
RE: Philco 42-400 121 - by Microtouch - 07-17-2015, 09:11 PM
RE: Philco 42-400 121 - by klondike98 - 07-18-2015, 11:13 AM
RE: Philco 42-400 121 - by mikethedruid - 07-21-2015, 07:32 PM
Update 42-400 - by Microtouch - 07-17-2015, 02:07 PM
