Philco 90 Ball of Confusion!
Mine has a 3903-R as part ( 18 ) also, with the letter R scratched into the side of the block. It has lugs at 4, 7 and 8.
Lug 4 has a wire running to volume control (20), also mica condenser (19) from lug 4 to ground at the mounting lug of ( 18 ).
Lug 7 has resistor (17) connected to it.
Lug 8 has resistor (50), a wire from multi-section condenser (30) and a wire running to resistor (49) connected to it.
The .01 uF condenser inside the block connects to lugs 4 and 7.
Hope this helps,
Ron.
Philco 90 Ball of Confusion! - by madghost - 02-19-2009, 12:59 AM
Re: Philco 90 Ball of Confusion! - by Ron Ramirez - 02-19-2009, 06:57 AM
Re: Philco 90 Ball of Confusion! - by madghost - 02-19-2009, 09:08 AM
Re: Philco 90 Ball of Confusion! - by Ron Ramirez - 02-19-2009, 09:32 PM
Re: Philco 90 Ball of Confusion! - by madghost - 02-20-2009, 09:15 AM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 2948 online users. [Complete List]
» 6 Member(s) | 2942 Guest(s)
AvatarAvatarAvatarAvatar
