41-280 Audio Output Wiring
Is it common for these push-pull sections to have the actual wiring reversed from the schematic?
So if you look at the schematic the Black and Black/White wires go to the lower tube. Mine has the White and Blk/Wht wires going to the top tube.
Looks like factory runs and solder before I got in there.
Thoughts?
41-280 Audio Output Wiring - by Edisla - 07-18-2015, 01:32 PM
RE: 41-280 Audio Output Wiring - by morzh - 07-18-2015, 04:32 PM
RE: 41-280 Audio Output Wiring - by Radioroslyn - 07-18-2015, 04:57 PM
RE: 41-280 Audio Output Wiring - by Edisla - 07-18-2015, 07:03 PM
RE: 41-280 Audio Output Wiring - by Raleigh - 07-30-2015, 12:32 AM
RE: 41-280 Audio Output Wiring - by codefox1 - 08-01-2015, 04:58 AM
There are currently 6005 online users. [Complete List]
» 1 Member(s) | 6004 Guest(s)
