41-280 Audio Output Wiring
The only thing I can think of is if the set has negative feedback wrapped around the output stage it may make a difference. I would leave it the way it was factory wired.
41-280 Audio Output Wiring - by Edisla - 07-18-2015, 01:32 PM
RE: 41-280 Audio Output Wiring - by morzh - 07-18-2015, 04:32 PM
RE: 41-280 Audio Output Wiring - by Radioroslyn - 07-18-2015, 04:57 PM
RE: 41-280 Audio Output Wiring - by Edisla - 07-18-2015, 07:03 PM
RE: 41-280 Audio Output Wiring - by Raleigh - 07-30-2015, 12:32 AM
RE: 41-280 Audio Output Wiring - by codefox1 - 08-01-2015, 04:58 AM
There are currently 6948 online users. [Complete List]
» 1 Member(s) | 6947 Guest(s)
