help with an old repair - 40-201 chassis
PS - We had a house fire 5 years ago. I DO NOT want to go through that again. 3 daughters, a wife, two dogs in a double wide on the front yard for a year. There are only a few people I would wish that on!!
RE: help with an old repair - 40-201 chassis - by David Van Wickler - 07-19-2015, 09:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5193 online users. [Complete List]
» 2 Member(s) | 5191 Guest(s)
