FINE TUNING ON 38-7
   I think I found the problem...This radio does not have any glas, or a ring   for the glass.I believe that there is a ring holding the glass in  and that is what the fine tuning dial would rub up against.  I don't have a photo of the glass installed..
      My next project will be to get the right ring and the glass.
  thanks for the clarification   Dan
   Living in Calgary Alberta
FINE TUNING ON 38-7 - by Dan Walker - 07-20-2015, 10:10 PM
RE: FINE TUNING ON 38-7 - by Ron Ramirez - 07-21-2015, 06:23 AM
RE: FINE TUNING ON 38-7 - by Chuck Schwark - 07-21-2015, 09:29 AM
RE: FINE TUNING ON 38-7 - by Dan Walker - 07-21-2015, 05:04 PM
RE: FINE TUNING ON 38-7 - by Chuck Schwark - 07-21-2015, 07:15 PM
RE: FINE TUNING ON 38-7 - by Dan Walker - 07-21-2015, 08:00 PM
There are currently 5559 online users. [Complete List]
» 1 Member(s) | 5558 Guest(s)
