Fun With Striped Wire
[DISCLAIMER: this worked for me but the wire mentioned here is *rated* at 50V - which means it is only tested by the manufacturer to that voltage]
Most of the Philcos I've repaired have wire harnesses to connect to the speaker. Often these wires aren't in great shape (missing insulation, patched with electrical tape) so of course I replace them with new cloth-covered wire. That gets the job done, but it doesn't look exactly like the original harness.
As an example, the original wire harness colors on my 16B tombstone:
  • white
  • green
  • green & white
  • blue & white
With only solid colors to play with this means I have to add two additional colors to the 'look' of the back. Icon_problem
I searched far and wide to see what kind of reproduction striped wire might be out there and came across Rhode Island Wiring Service - a small company that caters to antique automobile restoration. They manufacturer a wide variety of wire styles - but most are heavier gauge than those used in antique radios. I decided to take the plunge and order 25' in the closest style for each of my 16B's original colors (the wire cost 0.25/ft.):
18BPW  18ga Braided Primary Wire BU-4W
18BPW  18ga Braided Primary Wire W
18BPW  18ga Braided Primary Wire GN
18BPW  18ga Braided Primary Wire GN-2W
Decoder ring:
BU-4W = blue wire, 4 white tracers - kind of looks like original blue/white pattern
I would have preferred GN-4W = green wire, 4 white tracers, but they were out of that so I had to settle for GN-2W.
Anyway, here's what arrived in the mail:
And a side-by-side comparison between the old and new wire:
I created a new wire harness by measuring out 36" of each color and twisting them together. I then tied each end with a number of turns of brown thread bonded together with hot glue. Here's a comparison:
and the final result:
Fun With Striped Wire - by Nathan Slingerland - 07-21-2015, 11:18 PM
RE: Fun With Striped Wire - by Ron Ramirez - 07-22-2015, 05:48 AM
RE: Fun With Striped Wire - by Chuck Schwark - 07-22-2015, 09:15 AM
RE: Fun With Striped Wire - by Phlogiston - 07-22-2015, 10:28 AM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-22-2015, 10:53 AM
RE: Fun With Striped Wire - by Nick3092 - 07-22-2015, 11:33 AM
RE: Fun With Striped Wire - by TA Forbes - 07-22-2015, 11:38 AM
RE: Fun With Striped Wire - by Nick3092 - 07-22-2015, 12:08 PM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-22-2015, 02:40 PM
RE: Fun With Striped Wire - by Steve Davis - 07-22-2015, 04:33 PM
RE: Fun With Striped Wire - by ccomer1955 - 07-22-2015, 10:01 PM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-23-2015, 12:25 AM
RE: Fun With Striped Wire - by Alan Douglas - 07-23-2015, 01:25 PM
RE: Fun With Striped Wire - by TA Forbes - 07-23-2015, 07:46 PM
There are currently 4257 online users. [Complete List]
» 1 Member(s) | 4256 Guest(s)
