Philco 16B Switch Style
Repair job. The original would not have had a slot cut in it like that.
Oh, and the switch in your 16B-125 is for bass compensation, not AVC.
Philco 16B Switch Style - by Nathan Slingerland - 07-21-2015, 11:23 PM
RE: Philco 16B Switch Style - by Ron Ramirez - 07-22-2015, 05:46 AM
RE: Philco 16B Switch Style - by Radioroslyn - 07-22-2015, 06:38 AM
RE: Philco 16B Switch Style - by Ron Ramirez - 07-22-2015, 09:56 PM
RE: Philco 16B Switch Style - by Arran - 07-23-2015, 05:49 AM
RE: Philco 16B Switch Style - by Ron Ramirez - 07-23-2015, 06:34 AM
