Type of wire for antenna?
(07-22-2015, 11:26 AM)TA Forbes Wrote:  Are the NEC regs based on durability of construction or based on what kind of wire is the best conductor?
It is the National Electrical Code, and is based on safety first, and functionality second. I recommend following it as closely as possible for fire insurance reasons. If you have an improperly installed outdoor antenna, and it is hit by lightning, resulting in a fire, you could have insurance problems. They are also very good from the standpoint of functionality. They also coincide with the FCC rules governing antennae, although those are primarily concerned with transmitting antennae. There are parts of the NEC that pertain to transmitting antennae but I have not included them since here we are concerned with receiving sets.
Type of wire for antenna? - by sdradioman - 07-15-2015, 11:29 PM
RE: Type of wire for antenna? - by PAradiogeek - 07-16-2015, 07:35 PM
RE: Type of wire for antenna? - by Paul Philco322 - 07-16-2015, 08:15 PM
RE: Type of wire for antenna? - by Art Hoch - 07-19-2015, 10:35 PM
RE: Type of wire for antenna? - by TA Forbes - 07-20-2015, 01:09 PM
RE: Type of wire for antenna? - by Arran - 07-21-2015, 03:00 AM
RE: Type of wire for antenna? - by PhilcoJohn - 07-21-2015, 08:11 AM
RE: Type of wire for antenna? - by mikethedruid - 07-21-2015, 02:17 PM
RE: Type of wire for antenna? - by TA Forbes - 07-22-2015, 11:26 AM
RE: Type of wire for antenna? - by mikethedruid - 07-22-2015, 03:43 PM
RE: Type of wire for antenna? - by mikethedruid - 07-26-2015, 11:58 AM
RE: Type of wire for antenna? - by Paul Philco322 - 07-26-2015, 01:16 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
