Fun With Striped Wire
It looks to me like your new wire has as much insulation as the original wire. I wouldn't worry about.
M R Radios   C M Tubes
Fun With Striped Wire - by Nathan Slingerland - 07-21-2015, 11:18 PM
RE: Fun With Striped Wire - by Ron Ramirez - 07-22-2015, 05:48 AM
RE: Fun With Striped Wire - by Chuck Schwark - 07-22-2015, 09:15 AM
RE: Fun With Striped Wire - by Phlogiston - 07-22-2015, 10:28 AM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-22-2015, 10:53 AM
RE: Fun With Striped Wire - by Nick3092 - 07-22-2015, 11:33 AM
RE: Fun With Striped Wire - by TA Forbes - 07-22-2015, 11:38 AM
RE: Fun With Striped Wire - by Nick3092 - 07-22-2015, 12:08 PM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-22-2015, 02:40 PM
RE: Fun With Striped Wire - by Steve Davis - 07-22-2015, 04:33 PM
RE: Fun With Striped Wire - by ccomer1955 - 07-22-2015, 10:01 PM
RE: Fun With Striped Wire - by Nathan Slingerland - 07-23-2015, 12:25 AM
RE: Fun With Striped Wire - by Alan Douglas - 07-23-2015, 01:25 PM
RE: Fun With Striped Wire - by TA Forbes - 07-23-2015, 07:46 PM
