how to make leather handle for a 46-350 darker
Hello Ron,
Well I have not even compare mine far as length goes so I don't know if it's to short or not thats a goods point to check
far as being to light that is the only thing I see also I have real nice Zenith that they don't reproduce handles for to bad.
Sincerely Rich
There are currently 3727 online users. [Complete List]
» 1 Member(s) | 3726 Guest(s)
