Phonograph with Philco by Radiobar
Not a Radio Bar, but made by Radiobar. Here's a link: http://www.philcoradio.com/gallery/1938b.htm
Radiobar - by Patrick - 07-23-2015, 04:37 PM
RE: Radiobar - by Warren - 07-23-2015, 05:24 PM
RE: Radiobar - by Patrick - 07-23-2015, 05:33 PM
RE: Radiobar - by sam - 07-23-2015, 07:37 PM
RE: Radiobar - by TA Forbes - 07-23-2015, 07:37 PM
RE: Radiobar - by Patrick - 07-23-2015, 08:03 PM
RE: Radiobar - by morzh - 07-23-2015, 08:50 PM
RE: Radiobar - by Patrick - 07-23-2015, 09:02 PM
RE: Radiobar - by mikethedruid - 07-23-2015, 09:53 PM
RE: Radiobar - by Patrick - 07-24-2015, 01:08 AM
RE: Radiobar - by Patrick - 07-24-2015, 09:21 AM
RE: Radiobar - by morzh - 07-24-2015, 09:31 AM
RE: Radiobar - by Patrick - 07-24-2015, 09:47 AM
RE: Radiobar - by Patrick - 07-24-2015, 09:48 AM
RE: Radiobar - by KCMike - 07-24-2015, 04:44 PM
RE: Radiobar - by Patrick - 07-25-2015, 07:27 AM
Phonograph with Philco by Radiobar - by Patrick - 07-25-2015, 07:46 AM
RE: Phonograph with Philco by Radiobar - by sam - 07-25-2015, 12:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
