Info on 40-170CS
You won't be doing a lot of SW DXing, but that is one swell set!!! Icon_thumbup Icon_clap
Info on 40-170CS - by Patrick - 07-22-2015, 09:26 PM
RE: Info on 40-170CS - by shaler78 - 07-22-2015, 09:34 PM
RE: Info on 40-170CS - by klondike98 - 07-22-2015, 09:36 PM
RE: Info on 40-170CS - by Patrick - 07-23-2015, 08:21 AM
RE: Info on 40-170CS - by Arran - 07-24-2015, 06:44 AM
RE: Info on 40-170CS - by Patrick - 07-24-2015, 09:04 AM
RE: Info on 40-170CS - by TA Forbes - 07-23-2015, 11:18 AM
RE: Info on 40-170CS - by Patrick - 07-23-2015, 02:25 PM
RE: Info on 40-170CS - by klondike98 - 07-23-2015, 05:47 PM
RE: Info on 40-170CS - by TA Forbes - 07-23-2015, 07:39 PM
RE: Info on 40-170CS - by NN7X - 07-23-2015, 08:23 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
