Info on 40-170CS
I know that I'm just getting started here, but that the exact model I hope to find.
I remember sitting in Grandpas lap as he tuned a radio back in the early 50's ...never knew the radio but remember the experience.
Lee
Info on 40-170CS - by Patrick - 07-22-2015, 09:26 PM
RE: Info on 40-170CS - by shaler78 - 07-22-2015, 09:34 PM
RE: Info on 40-170CS - by klondike98 - 07-22-2015, 09:36 PM
RE: Info on 40-170CS - by Patrick - 07-23-2015, 08:21 AM
RE: Info on 40-170CS - by Arran - 07-24-2015, 06:44 AM
RE: Info on 40-170CS - by Patrick - 07-24-2015, 09:04 AM
RE: Info on 40-170CS - by TA Forbes - 07-23-2015, 11:18 AM
RE: Info on 40-170CS - by Patrick - 07-23-2015, 02:25 PM
RE: Info on 40-170CS - by klondike98 - 07-23-2015, 05:47 PM
RE: Info on 40-170CS - by TA Forbes - 07-23-2015, 07:39 PM
RE: Info on 40-170CS - by NN7X - 07-23-2015, 08:23 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7019 online users. [Complete List]
» 1 Member(s) | 7018 Guest(s)
