Please ID this PHILCO chassis
(07-24-2015, 06:31 AM)Ron Ramirez Wrote:
(07-24-2015, 12:25 AM)Frederick w. Taylor Wrote:  Thanks Steve for info, can you make one for me? what,s the damage$ on a new one from you unfinished?
How about a "plug" for my buddy Steve and his amazing work?
http://www.philcoradio.com/davis.htm
You will find all the info you need at this link. Be advised that the prices listed may have changed in the past three years, so on behalf of Steve, thanks in advance for your understanding.
Thank you Ron
Please ID this PHILCO chassis - by Fred Taylor - 07-22-2015, 10:42 PM
RE: Please ID this PHILCO chassis - by klondike98 - 07-23-2015, 01:02 AM
RE: Please ID this PHILCO chassis - by Arran - 07-24-2015, 06:23 AM
RE: Please ID this PHILCO chassis - by Fred Taylor - 07-24-2015, 07:57 PM
RE: Please ID this PHILCO chassis - by TA Forbes - 07-23-2015, 11:14 AM
RE: Please ID this PHILCO chassis - by TA Forbes - 07-23-2015, 07:36 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
