Very, Very nice!  Did you have to do much on the original finish?  It came out looking great!  Nice job.
Craig R.
42-345 - by NostalgiaRadioTime - 07-25-2015, 09:22 PM
RE: 42-345 - by VntgRads - 07-25-2015, 10:01 PM
RE: 42-345 - by NostalgiaRadioTime - 07-25-2015, 10:43 PM
RE: 42-345 - by tab10672 - 07-25-2015, 10:43 PM
RE: 42-345 - by Ron Ramirez - 07-26-2015, 08:11 AM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 11:49 AM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 11:51 AM
RE: 42-345 - by Arran - 07-27-2015, 02:50 AM
RE: 42-345 - by Paul Philco322 - 07-26-2015, 01:21 PM
RE: 42-345 - by Jayce - 07-26-2015, 02:44 PM
RE: 42-345 - by Paul Philco322 - 07-26-2015, 05:06 PM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 10:07 PM
RE: 42-345 - by tab10672 - 07-26-2015, 11:23 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6963 online users. [Complete List]
» 1 Member(s) | 6962 Guest(s)
