Using Gojo Creme on veneer
I use Non pumice Goop and 0000 steel wool.  I just cleaned up a 46-1203 last night and it came out looking great!  In fact I think I'll change my avatar from the refinished 48-1256 to the original finish 46-1203!
Using Gojo Creme on veneer - by TheUniversalDave1 - 03-16-2015, 11:07 PM
RE: Using Gojo Creme on veneer - by Art Hoch - 03-17-2015, 11:29 AM
RE: Using Gojo Creme on veneer - by OldRestorer - 03-17-2015, 11:51 AM
RE: Using Gojo Creme on veneer - by sdradioman - 05-28-2015, 08:17 PM
RE: Using Gojo Creme on veneer - by TA Forbes - 06-03-2015, 09:30 AM
RE: Using Gojo Creme on veneer - by KCMike - 06-03-2015, 01:08 PM
RE: Using Gojo Creme on veneer - by klondike98 - 06-03-2015, 05:10 PM
RE: Using Gojo Creme on veneer - by Art Hoch - 06-13-2015, 06:27 PM
RE: Using Gojo Creme on veneer - by Dan Walker - 07-12-2015, 05:40 PM
RE: Using Gojo Creme on veneer - by Fred Taylor - 07-12-2015, 06:05 PM
RE: Using Gojo Creme on veneer - by sam - 07-12-2015, 06:49 PM
RE: Using Gojo Creme on veneer - by Edisla - 07-12-2015, 11:42 PM
RE: Using Gojo Creme on veneer - by Fred Taylor - 07-13-2015, 12:28 AM
RE: Using Gojo Creme on veneer - by Squire - 07-26-2015, 12:44 AM
RE: Using Gojo Creme on veneer - by Eric Adams - 07-28-2015, 11:49 AM
