41-280 Color Scheme
Other than the thin lines on many of the edges on the head I am not sure what I should use.
The base is so worn out I can't tell if it is darker than the rest of the cabinet.
Thoughts on how I should tone this up???
41-280 finish - by Edisla - 04-26-2015, 01:09 AM
RE: 41-280 Color Scheme - by Edisla - 09-08-2015, 12:53 AM
RE: 41-280 Color Scheme - by klondike98 - 09-08-2015, 12:10 PM
RE: 41-280 Color Scheme - by Edisla - 09-08-2015, 05:08 PM
RE: 41-280 Color Scheme - by Fred Taylor - 09-11-2015, 10:00 AM
RE: 41-280 Color Scheme - by Edisla - 09-12-2015, 10:48 AM
RE: 41-280 Color Scheme - by Fred Taylor - 09-12-2015, 05:54 PM
RE: 41-280 Color Scheme - by Edisla - 09-13-2015, 01:13 AM
RE: 41-280 finish - by Fred Taylor - 04-26-2015, 11:21 PM
41-280 Color Scheme - by Edisla - 07-27-2015, 10:17 PM
RE: 41-280 Color Scheme - by Fred Taylor - 07-27-2015, 11:20 PM
RE: 41-280 Color Scheme - by Edisla - 08-01-2015, 10:28 PM
RE: 41-280 Color Scheme - by ccomer1955 - 09-02-2015, 10:36 PM
RE: 41-280 finish - by ccomer1955 - 09-02-2015, 10:39 PM
There are currently 6025 online users. [Complete List]
» 1 Member(s) | 6024 Guest(s)
