570 Grandfather
Hi and welcome, Blackflagger.
Have you tried Old-Time Replications? I believe they reproduce the knobs as well as the escutcheon for your radio.
http://www.antiqueradioknobs.com/
I believe there are other sources for reproduction escutcheons? I know there are other sources for the knobs. Look here:
http://www.philcoradio.com/resourceb.htm
570 Grandfather - by Guest - 12-23-2005, 07:45 PM
[No subject] - by 49Stude63 - 12-26-2005, 07:52 PM
[No subject] - by Ron Ramirez - 12-30-2005, 11:51 AM
Re: 570 Grandfather - by Guest - 03-26-2009, 12:12 PM
Re: 570 Grandfather - by Ron Ramirez - 03-26-2009, 06:59 PM
Re: 570 Grandfather - by Guest - 03-29-2009, 08:59 PM
Eico 232 VTVM Schematic
There are currently 7575 online users. [Complete List]
» 1 Member(s) | 7574 Guest(s)
