53-960 questions
Recheck your paper caps wiring to make sure they are where they are they are suppose to be. If miss wired  you maybe bypassing the signal to ground. Clean the band switch. Make sure that it is good and dry before applying power, don't want to set it ablaze.
53-960 questions - by doc612 - 07-28-2015, 05:18 PM
RE: 53-960 questions - by Radioroslyn - 07-28-2015, 07:37 PM
RE: 53-960 questions - by doc612 - 07-28-2015, 09:55 PM
RE: 53-960 questions - by Radioroslyn - 07-29-2015, 06:44 AM
There are currently 5908 online users. [Complete List]
» 1 Member(s) | 5907 Guest(s)
