37-675X Opinions
(08-01-2015, 06:57 AM)Radioroslyn Wrote:   It has the motorized dial.
Never seen one with a motorize dial! Dial is manual will presets. It's a good set but the 37-116 is a better one. You'll have to wait two more years for sets with rubber wire '39. But you are lucky (not) it does have a RF sub chassis just like the 37-116.
Terry,
My mistake on the terminology for the dial. Sorry. I do like the looks of the 37-116 better. This one is close to me so it became a little interesting.
37-675X Opinions - by SteveG - 07-31-2015, 11:19 PM
RE: 37-675X Opinions - by morzh - 07-31-2015, 11:38 PM
RE: 37-675X Opinions - by SteveG - 07-31-2015, 11:41 PM
RE: 37-675X Opinions - by sdradioman - 08-01-2015, 12:20 AM
RE: 37-675X Opinions - by Ron Ramirez - 08-06-2015, 03:04 PM
RE: 37-675X Opinions - by SteveG - 08-01-2015, 12:44 AM
RE: 37-675X Opinions - by Radioroslyn - 08-01-2015, 06:57 AM
RE: 37-675X Opinions - by SteveG - 08-01-2015, 09:56 AM
RE: 37-675X Opinions - by Radioroslyn - 08-01-2015, 05:26 PM
RE: 37-675X Opinions - by SteveG - 08-01-2015, 05:46 PM
RE: 37-675X Opinions - by TA Forbes - 08-06-2015, 12:50 PM
RE: 37-675X Opinions - by SteveG - 08-06-2015, 01:52 PM
RE: 37-675X Opinions - by w4rtc - 08-06-2015, 02:12 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7086 online users. [Complete List]
» 1 Member(s) | 7085 Guest(s)
