Philco 84 Restore
Hi Mark.  I have that same gimmick cap in my 41-280.  My guess is it works as a filter.  I don't know exactly how, but others on this site can offer more info than I can.  All I know is that I was told to keep it in the circuit or you can pick up a lot of "white" noise.  Take care, Gary
Philco 84 Restore - by markmokris - 07-31-2015, 11:09 AM
RE: Philco 84 Restore - by GarySP - 08-01-2015, 08:46 PM
There are currently 5756 online users. [Complete List]
» 1 Member(s) | 5755 Guest(s)
