  • 1 Vote(s) - 5 Average
Heirloom 41-250
Correction. According to a photo borrowed from here,
http://antiqueradios.com/forums/viewtopi...69&start=0
they are both frosted, but the one with the black painted tip is on top. Mine is not original, has one unfrosted replacement bulb. One of the beauties of that other restoration was that it was so original when badrestorer started
Heirloom 41-250 - by MarkBardenwerper - 07-09-2015, 10:48 PM
RE: Heirloom 41-250 - by klondike98 - 07-09-2015, 11:27 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-09-2015, 11:35 PM
RE: Heirloom 41-250 - by Ron Ramirez - 07-10-2015, 06:09 AM
RE: Heirloom 41-250 - by lenmiller - 07-10-2015, 12:45 PM
RE: Heirloom 41-250 - by KCMike - 07-10-2015, 02:34 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-10-2015, 10:13 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-12-2015, 09:46 PM
RE: Heirloom 41-250 - by TA Forbes - 07-13-2015, 01:36 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-14-2015, 10:01 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-15-2015, 11:26 PM
RE: Heirloom 41-250 - by Arran - 07-16-2015, 04:15 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-16-2015, 12:03 AM
RE: Heirloom 41-250 - by klondike98 - 07-16-2015, 01:41 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-16-2015, 10:16 PM
RE: Heirloom 41-250 - by Radioroslyn - 07-17-2015, 06:44 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-17-2015, 11:29 PM
RE: Heirloom 41-250 - by Radioroslyn - 07-18-2015, 06:56 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-19-2015, 01:06 PM
RE: Heirloom 41-250 - by jerryhawthorne - 07-19-2015, 03:20 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-19-2015, 09:40 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-29-2015, 10:10 PM
RE: Heirloom 41-250 - by Raleigh - 07-29-2015, 11:57 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 07-30-2015, 08:51 AM
RE: Heirloom 41-250 - by Raleigh - 08-01-2015, 04:33 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 08-02-2015, 08:41 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 08-16-2015, 11:03 PM
RE: Heirloom 41-250 - by codefox1 - 08-17-2015, 05:59 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 08-17-2015, 09:24 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 08-17-2015, 11:53 PM
RE: Heirloom 41-250 - by Raleigh - 08-18-2015, 04:35 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 08-18-2015, 08:45 AM
RE: Heirloom 41-250 - by Eliot Ness - 08-18-2015, 09:31 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 09-09-2015, 11:11 PM
RE: Heirloom 41-250 - by MarkBardenwerper - 09-09-2015, 11:26 PM
RE: Heirloom 41-250 - by Mondial - 09-10-2015, 08:19 AM
RE: Heirloom 41-250 - by MarkBardenwerper - 09-10-2015, 08:33 AM
