Model 70 progress
Only the early 90 with push-pull 45 output tubes used the power detector. The 90 with single 47 output and the 90 with push-pull outputs used a 27 wired as a diode as the second detector, producing cleaner sound.
Likewise, the early model 70s used the power detector - late versions did not.
Model 70 progress - by KCMike - 08-01-2015, 11:32 AM
RE: Model 70 progress - by Radioroslyn - 08-01-2015, 05:32 PM
RE: Model 70 progress - by KCMike - 08-01-2015, 06:52 PM
RE: Model 70 progress - by Radioroslyn - 08-02-2015, 10:14 AM
RE: Model 70 progress - by codefox1 - 08-02-2015, 06:38 PM
RE: Model 70 progress - by Ron Ramirez - 08-02-2015, 07:20 PM
There are currently 3484 online users. [Complete List]
» 1 Member(s) | 3483 Guest(s)
