help with an old repair - 40-201 chassis
Looking at blurry schematic off NA site looks like cap 77 is 25uf and cap 78 is 18uf I could be wrong about 77 ,guess it could be 2.5 but that dosen't sound right. If they are 18 & 25 you could use a 22uf 450v caps. If I'm wrong someone will correct this. Good luck
RE: help with an old repair - 40-201 chassis - by KCMike - 08-03-2015, 03:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7875 online users. [Complete List]
» 3 Member(s) | 7872 Guest(s)
