Found and Now Restored Model 70
49stude,
You were right about that. I actually forgot to mention that I restored the chassis too. That block had the original capacitor clipped out and was replaced with the one on the outside. After replacing the capacitors, a coil, the power cord, and the speaker wiring, it sounds like new.
Found and Now Restored Model 70 - by mikehorning - 01-12-2009, 08:06 AM
Re: Found a Model 70 - by rghines1 - 01-12-2009, 11:10 AM
Re: Found a Model 70 - by Uffda - 01-12-2009, 09:27 PM
Re: Found a Model 70 - by mikehorning - 01-13-2009, 06:57 PM
Re: Found a Model 70 - by gary rabbitt - 01-13-2009, 10:17 PM
Re: Found a Model 70 - by mikehorning - 02-22-2009, 09:58 AM
Re: Found and Now Restored Model 70 - by mikehorning - 02-22-2009, 01:03 PM
Re: Found and Now Restored Model 70 - by Arran - 02-22-2009, 11:25 PM
Re: Found and Now Restored Model 70 - by Arran - 02-25-2009, 01:33 AM
Philco 91 Tuning Condenser
There are currently 8754 online users. [Complete List]
» 2 Member(s) | 8752 Guest(s)
