Philco 41-280? Is it worth it?
All of the US Philcos after 1938 til post war production share something in common with Atwater Kent and Zenith sets RUBBER WIRE. Is a bit of a pain to replace.
Philco 41-280? Is it worth it? - by ccomer1955 - 08-03-2015, 02:49 PM
RE: Philco 41-280? Is it worth it? - by murf - 08-04-2015, 07:56 PM
RE: Philco 41-280? Is it worth it? - by KCMike - 08-03-2015, 04:06 PM
RE: Philco 41-280? Is it worth it? - by Arran - 08-04-2015, 03:52 AM
RE: Philco 41-280? Is it worth it? - by Arran - 08-05-2015, 12:10 AM
RE: Philco 41-280? Is it worth it? - by Radioroslyn - 08-04-2015, 06:13 PM
RE: Philco 41-280? Is it worth it? - by Warren - 08-06-2015, 01:13 AM
RE: Philco 41-280? Is it worth it? - by sam - 08-06-2015, 12:02 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
