Philco 37-611
Yes, that's the way the switch works. If it's 4 position 1st is on, the rest are different tone levels.
Philco 37-611 - by thinktreasure - 08-05-2015, 10:28 AM
RE: Philco 37-611 - by KCMike - 08-05-2015, 12:53 PM
RE: Philco 37-611 - by thinktreasure - 08-05-2015, 01:16 PM
RE: Philco 37-611 - by KCMike - 08-05-2015, 01:51 PM
RE: Philco 37-611 - by thinktreasure - 08-05-2015, 08:30 PM
RE: Philco 37-611 - by sam - 08-05-2015, 02:02 PM
RE: Philco 37-611 - by thinktreasure - 08-05-2015, 08:06 PM
RE: Philco 37-611 - by tab10672 - 08-05-2015, 06:24 PM
RE: Philco 37-611 - by thinktreasure - 08-05-2015, 08:33 PM
RE: Philco 37-611 - by Radioroslyn - 08-05-2015, 07:18 PM
RE: Philco 37-611 - by tab10672 - 08-05-2015, 08:31 PM
RE: Philco 37-611 - by tab10672 - 08-05-2015, 10:28 PM
RE: Philco 37-611 - by thinktreasure - 08-06-2015, 02:17 AM
RE: Philco 37-611 - by sam - 08-06-2015, 03:25 AM
RE: Philco 37-611 - by thinktreasure - 08-06-2015, 08:30 AM
RE: Philco 37-611 - by KCMike - 08-06-2015, 12:07 PM
RE: Philco 37-611 - by thinktreasure - 08-14-2015, 08:58 AM
RE: Philco 37-611 - by morzh - 08-14-2015, 10:08 AM
There are currently 7166 online users. [Complete List]
» 1 Member(s) | 7165 Guest(s)
