Philco 41-280? Is it worth it?
Curving wood usually entails soaking the wood and bending it into position, then letting it dry in that position.
Philco 41-280? Is it worth it? - by ccomer1955 - 08-03-2015, 02:49 PM
RE: Philco 41-280? Is it worth it? - by murf - 08-04-2015, 07:56 PM
RE: Philco 41-280? Is it worth it? - by KCMike - 08-03-2015, 04:06 PM
RE: Philco 41-280? Is it worth it? - by Arran - 08-04-2015, 03:52 AM
RE: Philco 41-280? Is it worth it? - by Arran - 08-05-2015, 12:10 AM
RE: Philco 41-280? Is it worth it? - by Warren - 08-06-2015, 01:13 AM
RE: Philco 41-280? Is it worth it? - by sam - 08-06-2015, 12:02 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
