I dont know what to do! Decision made, Restoration begun
Threads: 1
City: Ripon, Wisconsin
I know this is an old thread, but it is the first time I have seen GE LC-759 and it looks almost identical to my GE LC-758. I have one in my workspace that needs some cabinet work and a recap as well. I can see if I can get some pictures of the chassis underside if you need some more information for wiring. Don't know if I can help much on the phono side as mine has been hacked and replaced with a RCA model that does not fit very well.
(This post was last modified: 08-06-2015, 02:55 PM by heats00.
Edit Reason: typed wrong model #
RE: I dont know what to do! Decision made, Restoration begun - by heats00 - 08-06-2015, 02:49 PM
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
Thanks Arran;
I don't even know what a double conversion is, but i do have a good friend In Nova Scotia
that would k...Dan Walker — 07:01 PM |
