help with an old repair - 40-201 chassis
Right on the smaller uF values - I just had them in my hand and was wonder what is wrong with using such a high value and if would be detrimental
RE: help with an old repair - 40-201 chassis - by David Van Wickler - 08-06-2015, 05:44 PM
Users browsing this thread: 17 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8144 online users. [Complete List]
» 3 Member(s) | 8141 Guest(s)
