My new Philco 40-180!
Don't think Philco used any 6X5's, may have post war but pre war nah. I mostly find them in 6v car radios and Z brand sets. The 80, 5Y3, 5V4 are much heartier tubes but require a 5v filament winding on the power transformer. The 84 is an early version of the 6X5. Fortunitly it doesn't suffer from the same fail rate.
From my work bench I see those Philcos with the push/pull 41's and the 84 rectifier as a cost cutting set. From a design standpoint if Philco had used a more robust power transformer, a 5v rectifier, and a separate phase inverter they could have almost doubled the audio output and lower the distortion. Oh pardon me they did it's called a 41-300. As always everything come at a price.
My new Philco 40-180! - by TheUniversalDave1 - 08-08-2015, 09:58 PM
RE: My new Philco 40-180! - by TheUniversalDave1 - 08-08-2015, 10:00 PM
RE: My new Philco 40-180! - by KCMike - 08-08-2015, 10:04 PM
RE: My new Philco 40-180! - by TheUniversalDave1 - 08-08-2015, 10:51 PM
RE: My new Philco 40-180! - by shaler78 - 08-08-2015, 11:45 PM
RE: My new Philco 40-180! - by Radioroslyn - 08-09-2015, 08:45 AM
RE: My new Philco 40-180! - by Ron Ramirez - 08-09-2015, 12:40 PM
RE: My new Philco 40-180! - by Art Hoch - 08-09-2015, 05:34 PM
RE: My new Philco 40-180! - by TheUniversalDave1 - 08-09-2015, 07:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6785 online users. [Complete List]
» 1 Member(s) | 6784 Guest(s)
