38-116 off Craigslist
Did the 38-116 have a back cover?? I know that some of the older higher end sets had a cover over the spkr section for acoustic. Even with some vent hole at the top for the electronics would think it would get hot in there.
38-116 off Craigslist - by Groundhog74 - 06-03-2015, 09:42 PM
RE: 38-116 off Craigslist - by morzh - 06-03-2015, 09:47 PM
RE: 38-116 off Craigslist - by Fred Taylor - 06-03-2015, 11:03 PM
RE: 38-116 off Craigslist - by Groundhog74 - 06-04-2015, 04:12 AM
RE: 38-116 off Craigslist - by PhilcoJohn - 06-04-2015, 07:19 PM
RE: 38-116 off Craigslist - by PhilcoJohn - 06-04-2015, 07:20 PM
RE: 38-116 off Craigslist - by Fred Taylor - 06-04-2015, 08:36 PM
RE: 38-116 off Craigslist - by SteveG - 06-04-2015, 10:44 PM
RE: 38-116 off Craigslist - by Groundhog74 - 06-05-2015, 09:16 AM
RE: 38-116 off Craigslist - by morzh - 06-05-2015, 09:45 AM
RE: 38-116 off Craigslist - by Groundhog74 - 06-07-2015, 08:41 PM
RE: 38-116 off Craigslist - by KCMike - 06-07-2015, 09:01 PM
RE: 38-116 off Craigslist - by Fred Taylor - 06-07-2015, 09:50 PM
RE: 38-116 off Craigslist - by Groundhog74 - 06-09-2015, 04:25 AM
RE: 38-116 off Craigslist - by Fred Taylor - 06-10-2015, 09:32 AM
RE: 38-116 off Craigslist - by Groundhog74 - 08-08-2015, 09:16 PM
RE: 38-116 off Craigslist - by KCMike - 08-08-2015, 09:19 PM
RE: 38-116 off Craigslist - by Radioroslyn - 08-09-2015, 08:59 AM
RE: 38-116 off Craigslist - by Groundhog74 - 09-01-2015, 09:16 PM
RE: 38-116 off Craigslist - by PhilcoJohn - 09-03-2015, 08:06 AM
RE: 38-116 off Craigslist - by OldRestorer - 09-03-2015, 11:54 AM
RE: 38-116 off Craigslist - by PhilcoJohn - 09-03-2015, 12:04 PM
RE: 38-116 off Craigslist - by OldRestorer - 09-03-2015, 12:33 PM
RE: 38-116 off Craigslist - by radiohenry - 09-03-2015, 04:29 PM
There are currently 9850 online users. [Complete List]
» 3 Member(s) | 9847 Guest(s)
