25A6G + speaker match
Is there a valid sub for 25A6G?
The chassis I'm working on has a 25L6GT in place of it.
My sub books don't indicate this is a valid sub.
The chassis is a 37-611 connected to a AK speaker with a resistance of 500 ohms. The schematic calls out a 200 ohm speaker load on the output.
25A6G + speaker match - by thinktreasure - 08-10-2015, 01:46 PM
RE: 25A6G + speaker match - by Bob Andersen - 08-10-2015, 03:05 PM
RE: 25A6G + speaker match - by thinktreasure - 08-10-2015, 04:44 PM
RE: 25A6G + speaker match - by Bob Andersen - 08-10-2015, 07:09 PM
RE: 25A6G + speaker match - by thinktreasure - 08-12-2015, 06:19 PM
RE: 25A6G + speaker match - by codefox1 - 08-17-2015, 06:03 PM
RE: 25A6G + speaker match - by Radioroslyn - 08-17-2015, 06:56 PM
There are currently 4271 online users. [Complete List]
» 3 Member(s) | 4268 Guest(s)
