570 Grandfather
Hello,
I have a 1931 Philco 570 Grandfather clock, but it is missing the radio, the knobs as well as the backlite plate. What would you consider charging to make a clay or plaster mold of your backlite plate on your clock? I'm running out of options to have a reproduction made and finding an existing one is seeming impossible. I'd really like to get something made to at least place in there and I thought about making a mold copy from an existing one. Thank you for any consideration. Layne Chartrand of Troy, Missouri. 314-777-0587.
570 Grandfather - by Guest - 12-23-2005, 07:45 PM
[No subject] - by 49Stude63 - 12-26-2005, 07:52 PM
[No subject] - by Ron Ramirez - 12-30-2005, 11:51 AM
Re: 570 Grandfather - by Guest - 03-26-2009, 12:12 PM
Re: 570 Grandfather - by Ron Ramirez - 03-26-2009, 06:59 PM
Re: 570 Grandfather - by Guest - 03-29-2009, 08:59 PM
Eico 232 VTVM Schematic
There are currently 7483 online users. [Complete List]
» 2 Member(s) | 7481 Guest(s)
