1937 Philco 37-620 chairside and 1936 640 tombstone
Hello 49Stude63,
Ya that cabinet looks good to me to far as the picture show hows the glue blocks look are there any missing .
and your idea far as sandblasting go thats sounds like a plan far as your sandblaster goes is that one of the free standing cabinets with the built in rubber gloves a good friend that has a auto shop where I worked for while had one that was great tool to have If i had the room now at home I would have one .
Sincerely Rich
P.S. hows the tunning cap it's not frozen is it I have a Ge s-132 that has a frozen shaft .
Re: 1937 Philco 37-620 chairside and 1936 640 tombstone - by radiorich - 02-23-2009, 04:53 PM
Eico 232 VTVM Schematic
There are currently 6296 online users. [Complete List]
» 2 Member(s) | 6294 Guest(s)
