41-220 Electrical
Also this unit uses a resistor that I will call a dual output strip. It has three points one is suppose to be I believe (The Schematic is a bit blurry) 53ohms the second is 137ohms. The second measures out great right at 135 but the first is only at 3.6. Can anyone give me an idea of what the wattage of this resistor is so I can get a replacement?
'Daniel
PS if it helps the Philco part number is 33-3375 (The 5 is blurry but I believe it is a 5)
41-220 Electrical - by 2MERCS - 02-22-2009, 11:39 PM
Re: 41-220 Electrical - by 2MERCS - 02-23-2009, 04:56 PM
Re: 41-220 Electrical - by 2MERCS - 03-01-2009, 04:03 PM
Re: 41-220 Electrical - by exray - 03-01-2009, 04:34 PM
Re: 41-220 Electrical - by 2MERCS - 03-01-2009, 05:13 PM
Re: 41-220 Electrical - by 2MERCS - 03-03-2009, 04:57 PM
There are currently 10507 online users. [Complete List]
» 3 Member(s) | 10504 Guest(s)
