The glow don't mean a thing
For three days I have stared at a 42-380 chassis trying to find a problem. I recapped and replaced electrolytics, cut out crumbling rubber wire, cleaned pots etc. I could only get one station, and that so faintly I could barely hear it. I traced and retraced my steps, checked everything I could think of....this afternoon I thought Why not change the tubes? Well, I already did that 4 months ago when I bought the radio, but what the hey? And wouldn't you know it, the very first tube I changed (the 6X5 rectifier) the radio came to life and picks up stations better than any radio I have. Glowing doesn't necessarily mean working! I've only been restoring radios for about 7 months so I have a lot to learn, but this lesson goes in my book- It doesn't matter if you DID just buy that tube, put it on the tester!
The glow don't mean a thing - by doc612 - 08-12-2015, 08:45 PM
RE: The glow don't mean a thing - by Jim Koehler - 08-19-2015, 09:50 AM
RE: The glow don't mean a thing - by codefox1 - 08-19-2015, 09:26 PM
There are currently 5259 online users. [Complete List]
» 1 Member(s) | 5258 Guest(s)
