38-7 Speaker problems
I came across a 38-7 floor model this past weekend. It seems to be in good shape. Except for the speaker. Someone has ripped all of the wires loose. The output transformer is open. And the field coil is ruined, because wires have been broken on the winding. Any ideas on how, or if I can bypass the field coil and output transformer, and still use this speaker. Thanks!
38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 07:45 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 08:35 PM
Re: 38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 08:48 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 09:55 PM
Re: 38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 10:41 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 11:10 PM
