41-280 grill cloth?
I was thinking looking at mine that aa good cheese cloth dyed that color would be about perfect.
Charlie in San Antonio
41-280 grill cloth? - by lipfordm - 08-09-2015, 08:43 PM
RE: 41-280 grill cloth? - by lipfordm - 08-09-2015, 08:49 PM
RE: 41-280 grill cloth? - by lipfordm - 08-09-2015, 08:53 PM
RE: 41-280 grill cloth? - by sdradioman - 08-09-2015, 10:42 PM
RE: 41-280 grill cloth? - by lipfordm - 08-12-2015, 03:52 AM
RE: 41-280 grill cloth? - by ccomer1955 - 08-13-2015, 06:59 PM
RE: 41-280 grill cloth? - by lipfordm - 08-14-2015, 01:26 AM
