Mid-century portable 53-658
One of the local antique dealers called me about this little guy.  It looked to be in decent shape, had a battery still in it but hadn't leaked and was cheap enough.  Hopefully the leather will clean up nicely.  (it has the back to it as well, its just not in the pic)
[Image: https://www.dropbox.com/s/9izqnqj9hr365d....jpg?raw=1]
[Image: https://www.dropbox.com/s/izi1fkhvtj65q1....jpg?raw=1]
Mid-century portable 53-658 - by klondike98 - 08-13-2015, 10:18 PM
RE: Mid-century portable 53-658 - by sam - 08-14-2015, 03:28 AM
RE: Mid-century portable 53-658 - by Radioroslyn - 08-14-2015, 06:08 AM
RE: Mid-century portable 53-658 - by Arran - 09-01-2015, 03:37 AM
RE: Mid-century portable 53-658 - by codefox1 - 08-14-2015, 09:25 AM
RE: Mid-century portable 53-658 - by klondike98 - 08-14-2015, 12:21 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-14-2015, 03:30 PM
RE: Mid-century portable 53-658 - by Raleigh - 08-16-2015, 09:03 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-16-2015, 11:17 PM
RE: Mid-century portable 53-658 - by Eliot Ness - 08-17-2015, 06:41 AM
RE: Mid-century portable 53-658 - by klondike98 - 08-17-2015, 11:19 AM
RE: Mid-century portable 53-658 - by sam - 08-17-2015, 12:46 PM
RE: Mid-century portable 53-658 - by codefox1 - 08-17-2015, 05:56 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-17-2015, 07:03 PM
RE: Mid-century portable 53-658 - by klondike98 - 08-18-2015, 01:15 PM
There are currently 4278 online users. [Complete List]
» 3 Member(s) | 4275 Guest(s)
