Grandfather clock radio combo
So you have an artifact of questionable heritage (like me.) We will help you to get if fixed and working if that's your goal.
Grandfather clock radio combo - by thinktreasure - 07-31-2015, 01:20 PM
RE: Grandfather clock radio combo - by sam - 08-01-2015, 04:30 PM
RE: Grandfather clock radio combo - by AI2V - 08-01-2015, 10:12 PM
RE: Grandfather clock radio combo - by AI2V - 08-02-2015, 09:43 PM
RE: Grandfather clock radio combo - by codefox1 - 08-14-2015, 09:32 AM
RE: Grandfather clock radio combo - by wa2ise - 08-15-2015, 09:25 AM
RE: Grandfather clock radio combo - by sam - 09-11-2015, 03:00 AM
RE: Grandfather clock radio combo - by codefox1 - 09-15-2015, 03:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
