38-7 Speaker problems
These should be common speakers, Gary at playthings of the past might have both items, he typically is extremely reasonable on this prices. If you can find the speaker part number I will look thought his site and see what he has or you can follow this link http://www.oldradioparts.com/2a32fl.txt
and see what you can match up.
38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 07:45 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 08:35 PM
Re: 38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 08:48 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 09:55 PM
Re: 38-7 Speaker problems - by yesterdaysradios - 02-23-2009, 10:41 PM
Re: 38-7 Speaker problems - by 49Stude63 - 02-23-2009, 11:10 PM
There are currently 9734 online users. [Complete List]
» 1 Member(s) | 9733 Guest(s)
